Roundabout voice direction incorrect in LH Drive nations
Now that 28.34 has fixed the icon for right-hand turns on roundabouts to show the correct path around the roundabout and actually be the 3rd exit, the voice prompt still says "take the first exit" instead of "take the third exit".  Seem to have missed something there.
  • See screen shot below. At a crossroads that has a small roundabout the course is straight ahead, which is the second exit, but the navigation prompt at the top of the screen says third exit, which would take me right rather than straight ahead.
    I also noticed while riding this course this morning (first course I've ridden since the upgrade to 28.34) that there are now two position indicators (see screenshot below). There's a grey indicator that is ahead of my present location, and the normal blue indicator that is my present location. I've never seen the grey indicator before.
    Edit: and another instance of the same problem on my ride yesterday. The course requires exiting the roundabout at the first exit, but the prompt at the top of the screen days 2nd exit:
  • The second grey one is the much maligned "Virtual Partner", you can since 28.20 turn it off , 28.20 also suposedly "fixed" the incorrect roundabout symbols/descriptions which were showing the wrong directions, garmin might still have some work to do?
  • LH drive country here as well - I don't use voice navigation, but the on-screen prompts for which exit to take at roundabouts are also still wrong with 28.34. See https://forums.garmin.com/sports-fitness/cycling/f/edge-1050/422445/28-34-incorrect-navigation-prompts-at-roundabouts.
  • Thanks for your post, I have raised a support ticket to investigate prompts and voice prompts for left hand drive regions.
