My unit has always shown a reasonably accurate estimate on how many hour of battery life left on the unit, showing aprox. 22-23 hours when charged to 100%. After updating firmware to 28.20 the hours estimate is more than double what it should be (ie. more than 54-56 hours left at 100%). As an example, the other day i did a 2 hour ride, estimate was 15h when i started and finished at 5h... On yesterdays ride by the time i had done 30-35 minutes the estimate had reduced by 2 hours.
I have not changed any setting on the device nor turned on the battery saver feature. Only change has been the updated firmware. I've tried resetting the device without luck.... I'm thinking this has to be a bug, but since i haven't seen anyone with similar issues or Garmin release a fix with the last update i'm not so sure anymore...
Just to clarify, actual battery consumption has remained constant across different firmwares.
Any ideas on how to get this fixed?
