Is there a way to set audible beep with lap change
Is there a way to set an audible beep with every lap change?  I am pretty sure that with my 530 I had that. (although I may be remembering it incorrectly).
Also, in a semi unrelated question........I read, prior to buying the 1050 that it had the option of voice prompts, yet a month later and a couple firmware updates later, I have yet to hear one.   Let me preface this by the fact that in the long run, I probably will turn most of them OFF, but I do want to hear what ones are available and then decide.
Am I missing something?  Perhaps I have them turned OFF by default?   What things are available to use voice prompts with? I have not used any navigation or set courses yet, and perhaps that is the reason why I have not heard any voice prompts?
Thanks in advance.
  • Just as an addendum, after this last firmware update, I think they have actually fixed a bug or added a beep on auto lap change, although it is very soft, even with my Sounds slider all the way at maximum.   Perhaps if Garmin reads this post.....if you can make the lap beep changeable by Sound volume slider and then perhaps make it a bit louder, I would appreciate.  Thanks  (I think it was Firmware v. 28.33)
