Crash during activity lost gps of part of activity
I tracked with my 2 week old edge 1050 a 100km ride and one hour after the start it crashed and rebooted the device. It showed as it continues tracking the ride and therefore I was confident that it works.
But also my Garmin varia only partly worked (the light went one when connected but the radar didn't work).
After I while i tried to fix it by rebooting the device again and after thst the final fit file looks to work again.
My question ist this a common issue because the I think I will return the edge and is it just s matter of time thT it happens again? Because this is the most important thing that the tracking just works. But for now I want to know if i can fix my fit file to get the correct activity data where 2h are missing. See attached fit file.
19783342808_ACTIVITY.fit
  • Same issue.  I think it restarted the ride in an indoor profile vs the previous outdoor profile.  Indoor has no gps.  It gave me some info about indoor as well.
    • this seems like a bug, it should restart in the same profile.
  • Hallo @3677607 In Deiner Datei gibt es einen GPS-Ausfall (unexpected big change of distance value) zwischen Marlstein und Innsbruck Westbf.
    Auf der Kartenansicht wird das als gerader Strich angezeigt.
    Ich habe Deine Datei trotzdem konvertiert*, Du wirst allerdings nicht zufrieden sein. Deshalb mein Vorschlag. Wenn Du noch über die Planungsdatei verfügst, kannst Du mir diese schicken (GPX, FIT o.ä.). Diese könnte ich mit der Aktivitätsdatei kombinieren, allerdings fehlen dann für die Zeit des GPS-Ausfalls die Werte für Kadenz, Leistung ...
    * drive.google.com/.../view
