Screaming into the abyss that is the Garmin software team.....
I picked up a 1050 as an "upgrade" from an 840. Purchase was motivated by desire for better screen and better software.
The screen IS a huge improvement.
The software is extremely problematic. (13.14 release, not beta)
- Device restarts and freezes
- Map updates can take multiple hours even when connected to WiFi / USB
- Initially I started a map update from the 1050 directly. When I saw it was supposed to take 7hrs, I connected to GarminExpress and started the map update there. When complete, and even after a device restart, the 1050 still had the first update "queued". I had to manually cancel the first update.
- Migrating sensors at initial setup is worthless. It says it completes and all the sensors are listed on the 1050, but the only sensor that actually connects is the Polar HRM. ALL the others won't connect. Deleting/removing from 1050 and adding them again works perfectly. It would be better if the setup process just said "now go add all your sensors. It will be annoying but it will only take a minute." Instead of creating a situation that requires users to troubleshoot.
- Data screens - WE STILL CAN'T NAME THEM?!?!? We can rename sensors but not custom data screens. Oh Garmin, you kill me.
- Virtual Partner - Still can't disable this POS feature? Insanity.
- Screen brightness : Auto mode is a nice idea but invariably the screen winds up being too dark. Setting the brightness manually works, but then you know, it isn't variable. It would be better if you could set the min/max brightness and let the auto do its thing. Or even better, let a user calibrate the desired brightness for different ambient levels. Put that on the list of things that will never happen.
Now the big problem - The navigation and turn by turn directions..... Aside from being a datalogger, navigation is the CORE function of these devices. Unbelievable that this is so bad.
Some examples:
1) Course Routing is really broken - I created a route in Strava. It synced as expected. I rode the first 30 or so miles of the course and it worked as expected. There wound up being a problem with the route that made it impassable and required some going off-course to get around the problem. This was just a real world problem, nothing to do with the 1050. However, it resulted in a fairly significant deviation from the original course. At the time, I didnt think anything of it, and expected the 1050 to continue recalculating the navigation and pick up the course again as I got closer to intersecting it. Instead, the 1050 continued to try to get me back to original course close to where I had to go off-course, not get me to the course at the point nearest my current location. The latter is the expected behavior.
I found my way back to the course (within 1/4 mile), but instead of simply picking it up from that location, the 1050 sent me the wrong direction (now going against the original course direction) on an out-and-back (into a nonstop headwind no less) to reach the point on the course that it had previously chosen. Eventually I reached the arbitrary point it was navigating me to and it found the course. I knew something was wrong, and I should have verified sooner. I finally confirmed what my gut was telling me by pulling out my phone. I canceled the course navigation, and started the same course again. It immediately directed me to navigate BACK to the same location where I had been within 1/4 of the course to join the course. It was too late, I had wasted too much time and energy because of bad directions and I had to abandon my original ride plan.
2) Turn-by-turn on trails is useless - In addition to the above problem of how off-course conditions are handled, this is all made worse when riding complex trail systems with many turns close together.
- The turn by turn notifications appear sometimes but not others.
- Turn warnings don't update quickly enough. Yesterday I was riding and it said 0.1 mile ahead. I passed the actual turn and it still said 0.1 mile ahead. Then it updated and said I was off course. Multiple turns in quick succession are even worse. It misses those 100% of the time. Even if it gets the first one, it doesnt update fast enough to help with the ones that follow. This is maddening because it means that I have to stop at every trail junction and manually inspect the trail map. Sometimes it will update the distance ahead (400ft, 100ft, etc) - but not always.
- The new feature to provide a zoomed view of the intersection is nice, except it only pops up when I stop at the intersection. It might actually be helpful if it popped up BEFORE I get to the intersection so I don't have to stop.
- The course line is hard to follow
Many of these issues are reported by many other users already. I don't think I'm experiencing anything new or unique. I also don't think I'll be experiencing them for long because this device will almost certainly be returned next week. I've been down the path of "new device. new problems. give them time to fix." --- The trouble is that this isn't a new device. Core functions like navigation should not be riddled with problems.
Ace and Karoo have their own challenges for sure, but surely one of them can get navigation right.
Ok. Rant over.
