Hi, I want to connect my 1050 on my windows 11 pc. He goes in th epc Modus. But my pc recognizes him as a unknown device with missing driver. Garmin Express doesn't find the 1050. I tried also to download the old driver but it doesn't work.
What do you mean with “epc Modus”?
The Edge 1050 doesn’t need a driver. It communicates with the computer with MTP, which is supported in Windows 11 without any additional drivers.
If you use an USB hub, try connecting the Edge directly to your computer instead of via a hub. Also try different ports on your computer and try a different cable to see if that helps.
