12.18 firmware
when i stop moving, the map is rotated slightly off, it points to the side about 20 degrees, at the same time edge 530 rotates map correctly. i tried to calibrate it without success.
is this expected behavior?
12.18 firmware
Same problem with mine, but it rotates way more, makes navigation on the trails really hard sometimes. It may also toggle the map back and forth
This is bad, really bad as it makes the device unreliable…
Garmin please just allow to turn off this auto align "feature" it's clear that it's designed to show the compass in correct orientation no matter how you hold it, but normally, you're not holding it, it…
I have the same problem with my stem-mounted Edge. But when I take the device off and raise it by 30 cm, the compass points correctly.
It seems that there is a magnetic interference.
My 1050's compass does not point exactly north - no matter how often I perform the (much too fast) calibration.
But the display remains stable - regardless of the tilt.
