Edge 1050 continues to asking to connect to devices already connect
After ride has started and my devices have connected, it will continue to ask if I want to connect to these devices. Regardless if I select yes/no, it doesn't matter. I have tried forgetting devices and reconnecting, factory reset, and this is only the 4th use.
Top Replies
  • thanks for your post.
    Removing and un-pairing your sensors should prevent repeated sensor found or switch connection type messages.
    We have identified the root cause of this repeated sensor found…
All Replies
    We have identified the root cause of this repeated sensor found message and a fix is live in the currently available beta version 13.09 for Edge 1050. These updates will be in the public software releases over the next few weeks.
    If you continue to experience this behavior after updating or have further questions, please let me know.
  • I have tried the formentioned fixes multiple times during rides and at home. I will have to wait for the updates,  I guess. Thank you for the assistance
  • Same issues not one device multiple device and you can cancel
  • Still issues my software version 13.13  disaster
  • same thing here.  I have multiple power meters on different bikes.   This issue kept going on 5ish minutes into the ride.
