I tried to plug it , push all the button … still nothing
plug it in to a charger for at least 10 minutes and then keep pushing power for 45+s to trigger full reset. Then turn on as normal. If that does not work you have a brick. Garmin warranty support may help.
There's a random bug causing Edges to hang in their sleep and drain battery.
The Edge 605/705 manual says to press the Mode and Lap buttons for 10 seconds to reset the device. The Edge 800, 1000, 1030, 1030 Plus, and 1040 manuals all say to press the Power button for 10 seconds to reset the device. The Edge 1050 manual says to press the Power button for 12 seconds. I had a similar problem to yours recently, and I think I pressed the Power and Lap buttons until the unit restarted, and it may have taken more than 12 seconds. It's possible that the Edge 1050 just ignored the fact that I had pressed the Lap button along with the Power button. Anyway, it worked....
