Climb Pro screen on Edge 1050 pops up when climb approaches, it says the banner Climb! but then Climb Pro Screen doesn't stay on
I just recently bought this 1050 unit.  the first rides I rode with it I could observe the following pattern every time I approach a climb:
  • Climb approaching--> Climb Pro screen popped up, describing the climb, and the distance remaining to reach it. the Climb Pro screen popped up while using any other screen.
  • starting the climb--> Banner saying Climb! shows up.
  • After Climb! Banner disappears--> unit switches to Climb Pro screen, from screen used while the climb was detected/ started.
  • Once climb is finished Climb Pro reports out the climb time completion and unit switches back to previous screen used.
After reading the manual and different questions for similar issues, my understanding of how the feature works is as it is described above (i.e. Climb Pro screen stays on during the length of the climb)
Since then, I changed the custom fields (adding 4 fields instead of 2).
Something changed in the way that Climb Pro operated. below a description of above process with the change highlighted.
  • After Climb! Banner disappears--> unit stays in  screen used while the climb was detected/ started. Climb Pro screen is available but, after scrolling multiple screens.  It doesn't stay anymore
I have checked all potential configuration set ups on the climb pro screen  and nothing seems to correct the issue.
I have the latest software (11.24) and latest maps for North America (2024.20)
Does any one has experienced the same issue? It is my understanding of how the feature works the correct one?  Thanks in advance.
