Reboot on 11.24
Since i have firmware 11.34 my device reboot every time i do a ride.. most after 2 hours i have a reboot.
  • I experienced a similar issue today. I did a 3-hour ride and after about 2 hours, my device suddenly rebooted. I had previously opened a ticket with Garmin support, and they suggested sending the unit in for service, but I held off, hoping a new firmware would solve the problem. Now I’m starting to lose hope.
    I came across another user’s post describing the same issue, and it seems like Garmin is aware of it and is even replacing certain units that fall under specific lot numbers. Check out this link:
    https://forums.garmin.com/sports-fitness/cycling/f/edge-1050/378526/two-system-reboots-on-today-s-ride/1820305#1820305
    I’m starting to think I should just go ahead and contact Garmin again to arrange a replacement.
  • I also still have some reboot problems on 11.24. Today i tried to set a point to navigate on the map. The device showed „out of memory“ Then tried a second time and again this Message. After 10 seconds the device just crashed. The reboots really are getting frustrating.
  • I'm facing the same issue since 2 weeks ago. So far never happened, and in my last 4 rides it happened 4 times (one ride was fine, but it crashed and rebooted 2 times in one day) which is disgusting
    Seems some other people is having the same issue. Did you guys fix it somehow?
