Firmware version 11.24 for the Edge 1050 Series is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
Changes made from version 10.19 to 11.24
- GroupRide
- Fixed GroupRide dynamic glance failing to update with finished ride data.
- Fixed GroupRide awards getting reset after a power cycle.
- Garmin Coach
- Fixed an issue where the dynamic area would not update with the Garmin Coach workout.
- Fixed Garmin Coach workout not showing as complete in the Garmin Coach glance.
- Fixed issue where device wouldn't show some Garmin Coach plans in the Garmin Coach widget.
- Fixed an issue where Garmin Coach workouts wouldn't sync.
- Updated the jump tone to make it easier to hear.
- Prevented device from entering MTP mode when it is turned off, but Bike Alarm is active.
- Removed legacy FTP test.
- Lactate Threshold estimates are applied automatically after training with heart rate.
- Added new compass data field.
- Added new map data field.
- Added 10s/30s average power graphical data field
- Added a confirmation message for successful manual altimeter calibration.
- Fixed double radar overlay in the Connect IQ Store.
- Fixed pairing to inReach Messenger Plus.
- Fix map track-line issues.
- Fixed phone connectivity issue
- Fixed mismatching navigation arrow and distance to next arrow.
- Muted notifications while bike alarm is set since it was triggering the alarm.
- Fixed issue where elapsed timer would work incorrectly after suspending device during an activity.
- Fixed an issue where record messages would fail to record periodically and leave gaps in the activity file when the phone was connected.
- Fixed overlapping timed alerts failing to alert.
- Fixed recovery heart rate writing to an incorrect field in an activity file so that Garmin Connect would fail to display it.
- Fixed consistency of Climb Pro behavior on looped ride.
- Fixed route recalculation errors after deviating from planned course.
- Fixed issue where a course with a very slow Virtual Partner could crash the device.
- Fixed crash when processing Bluetooth data.
- Added new SRAM gear presets for 13 speed gravel groupsets.
- Fixed issue where screen would display "snow" on power up.
- Updated Shimano STEPS terminology to "Shimano E-bike".
- Fixed ability to use the bell while audio prompts are playing.
- Fixed Back to Course calculation that requires a u-turn.
- Fixed layout of graphical data fields.
- Fix issue where both heart rate and power zones could overlap.
- Fixed Di2 battery data field to update with proper battery level.
- Fixed an issue where the sounds menu settings would fail to save.
- Fixed issue where the weather widget would have valid data but fail to show it.
- Fixed layout of map browsing page to show the map scale when a location is selected.
- Fixed truncation of climb length on climb complete prompt.
- Fixed some text layout issues.
- Fixed grade value acting erratic after a suspend/resume cycle.
- Fixed Stamina Distance to Go units.
- Updated the icon displayed when the Edge is connected to a computer.
- Fixed a crash that could occur on power down.
- Fixed data screens with maps showing the wrong layers.
- Fixed various bugs and crashes.
Changes made from version 10.18 to 10.19:
- Fixed memory leak issue that could cause a crash
Changes made from version 9.11 to 10.18:
- Added Garmin Share. Share your workouts, courses, and waypoints between compatible Garmin devices.
- Added ecosystem-wide Garmin Coach support. Train for an event, achieve a milestone, or improve your fitness with dynamic Garmin Coach training plans for runners and cyclists.
- Added GroupRide awards and climb competitions.
- Added road hazards support. Get alerts for road hazards reported by fellow cyclists and contribute your own edits.
- Added wind and stamina adjustments to Power Guide.
- Added surface type support including on the map, in-ride unpaved road alerts, and post-ride summary.
- Added Wi-Fi map download support.
- Added revamped Course Creator.
- Updated grade algorithm to be much more responsive.
- ClimbPro
- Fixed climb clusters failing to display climb details.
- Fixed an issue where the climb list page could highlight the incorrect current climb.
- Fixed climbs drawing on a course when ClimbPro is disabled.
- Retained the setting for the ClimbPro, Segment, and PowerGuide slider between page uses.
- Added support for India basemap.
- Added gear presets for SRAM 12 speed cassettes.
- Added a QR code to quickly pair a Strava account with Garmin Connect.
- Added search alias support to improve location searching.
- Added course search to the search bar.
- Fixed USB connection detection when coming out of suspend mode.
- Fixed crash that could occur when saving the ride.
- Fixed incident detection countdown timeout notification priority over any other notifications.
- Fixed infinite elevation calibration prompt following a manual calibration.
- Removed tone from elevation calibration prompt.
- Fixed mute toggle interactions on the notifications widget.
- Fixed pausing navigation.
- Improved speed of city search.
- Improved phonetic and hand-writing keyboard input.
- Fixed ride button failing to show after receiving and reviewing a Connected POI.
- Fixed friendly name for phone pairing.
- Fixed issue where hazards in China could appear offset on the map.
- Set minimum backlight level to retain screen visibility after backlight timeout expires.
- Persisted backlight level setting through battery saver enable and disable.
- Fixed battery remaining time estimate not updating when toggling Hide Map option in battery saver menu.
- Fixed display of battery level when it dropped below 5%.
- Fixed small roads on map being drawn too thick.
- Fixed behavior of menus from popping back to previous page to remaining on page after data entry.
- Fixed an issue where British coordinates could not fully be entered with the keyboard.
- Improved layout of post-ride highlights page.
- Fixed various crashes and freezes.
Changes made from version 9.09 to 9.11:
- Improved performance of hazards including fixing an issue where a hazard would not prompt.
- Fixed an issue where Power Guide target could display incorrectly after a climb.
Changes made in version 9.09:
- Updated GNSS firmware to 11.00
- GroupRide Improvements:
- Added descriptions and fixed values for GroupRide awards.
- Fixed issue where GroupRide shared code is lost if consent is required.
- Removed redundant time information in competition results.
- Fixed GroupRide course not downloading and failing to display after a ride.
- Fixed layout of awards list items.
- Fixed awards taking a long time to show up in history.
- Fixed errant climb competition winner when climb doesn't register as a competition.
- Fixed showing start distances for competitions.
- Fixed issue where a hazard would still be visible after a downvote on a ride.
- Added a QR code to quick link to pair a Strava account with Garmin Connect.
- Integrated CIQ glance theme support.
- Fixed crash that could occur when updating Power Guide.
- Fixed crash that could occur when navigating back to start.
- Fixed crash that could occur when using course creator.
- Fixed freeze that could occur during WiFi sync.
- Fixed key press behavior when battery saver display timeout is active.
- Fixed issue where a specific sequence could result in double swiping on timer loop pages.
- Fixed high power consumption on the map page after loading a course.
- Fixed battery saver estimate accuracy.
- Fixed showing the battery was charging when the temperature range was exceeded, and battery was not in a charging state.
- Fixed layout on the segment/climb dual approach prompt.
- Fixed multiple issues with graphical data fields.
- Added highlight to the selected data field.
- Fixed font size for large data fields.
- Added real-time settings menu for voice prompt settings.
- Fixed display of unpaved data in course summary.
- Fixed activity profile odometer not refreshing after a ride.
