Courses not showing up
I cant find courses that I recently uploaded... just the last two days.  I can see them when I connect the 1050 to my laptop... they are on the drive... I can see them when I connect to Garmin Connect...  but when I go into navigate on the 1050 it does not show these in the courses ????   Any ideas???
  • 2 possible reasons:
    1) do you have more than 100 courses stored?
    2) the course name is not the file name but the internal xml tag <name>. Maybe there are more courses with the same internal name.
  • Nopes on both accounts...
    Computer is brand new and I've only downloaded 4 other files prior to this happening.
    Not certain how to check that, but seems like if that were the case there would be a file showing up with a different name?? And there isn't. But,  also pretty sure the name is the name and not the tag,  i just checked for the name and see it as the name on garmin connect and on the 1050 memory... ThinkingUnamused
    Thank you for those suggestions.  Wish it were one of them...
    Any other thoughts?
