Strange "Crash" last ride (Display freeze)
Hello,
encountered a strange sort-of-crash last ride:
- after around 30km the display was frozen. Buttons did not do anything, looked like a complete crash
- after another 10km im managed to turn it off (i thought) using long presses on power and lap button (it was hard cause I was wearing long gloves and was riding in a group, so did not want to pause)
- then no restart was possible with hitting power button, the display stayed black
- at home i did fiddle around with power + lap button long press and suddenly the unit turned on again
- strange result: it showed the complete ride including all sensor data and I could save it. So the unit never really crashed.
Anyone else experienced this?
  • i the only thing you can do if you're garmin is still under warranty I believe it's a two-year warranty garmin give is contact Garmin and Report the problem to them send it to them and they should replace your unit free of charge under warranty
  • They offered it to replace it with a refurbished unit. But since it is quite obviously a software-bug that would make no sense in my opinion.....support says they havent got no reply from the software-development too from the bug-reporting so far....
  • While looking at the 12.xx firmware beta bug report posts, I found someone who probably posted the same thing as this issue. The status was under review, so I thought the development department was aware of the problem in some way.
    If the battery saver cannot be used, the company will no longer be able to advertise its published operating time of 20 hours (up to 60 hours when using battery saver), so I can imagine that it will be at a disadvantage in competition with other companies' products, but what I cannot forgive is that they set up a system at startup to prevent users from using the battery saver, and while they comment on other posts, they continue to ignore posts here and do not provide any prospect of a solution.
    I noticed this freeze abnormality from firmware 11.24, but I have installed an inquiry to prevent battery saver from being used at startup from firmware before that. This is the ◯word, to say the least.
  • I had the same problem, frozen unit... i ask them yo replace the unit for a new one, i am still waiting.
  • Beta v13.07 ist out now. Changelog still does not mention anything with battery save mode. But will try it anyway.....
  • I had a similar problem today. I turned on battery saver mode, but after some kilometres, the screen froze. I turned it off with a long press, turned it on, and it seemed to work again. I saw it was recording, but it didn't save any data from there.
    Will they fix this freeze issue?
  • As a new owner of 2 weeks I have experienced this twice now, with Varia RTFl515 and in battery save mode. Not using battery save mode I have not. The data is saved when I do a long reset with power button so it was not really crashed though screen was locked. It woke up due to radar detecting car in both cases.
  • still not fixed in beta 13.12
    and garmin ignores this bug completely, at least on the forum here. for other bugs they say at least that they are working on it (even if they usually dont manage to provide fixes as well....see the low temperature freeze topic). here nothing.....i guess its soon time to sell the 1050 and move on
  • So, problem is solved for me: I sold the 1050 and went back to 1040. Will miss the display, but at least I have reasonable runtime again......
  • With 13.14 the 1050 is very stable in my experience. Even better than 1050.
