Edge 1050 and Assiomo Pro MX-2? does it work?
Hi. I would like to by Edge 1050 and Assioma Pro MX-2 and I am wondering if they work together? I did not fin any informations on Assioma web site.
Best
Perry
  • Yes.  They do, specifically, but you'd be hard pressed to find a PM that doesn't. Currently I'm using Zwatt, Assioma, and Sigeyi power meters on different bikes, and of course my Saris smart trainer works too.
  • Yes, I can confirm that the Edge 1050 is compatible with the Favero Assioma Pro MX-2, as I own and use both. Additionally, I also use the Favero Assioma DUO-Shi, which is also fully compatible with the Edge 1050.
    However, I've noticed an issue when switching between the two power meters across different rides. Specifically, if I used the Assioma DUO-Shi on my last ride, the Edge 1050 doesn’t automatically reconnect to the Assioma Pro MX-2 on the next ride. To resolve this, I have to go into the sensor list and manually reconnect the Pro MX-2.
  • >>>I've noticed an issue when switching between the two [Assioma] power meters across different rides.<<<
    I haven't run into this (yet) but then don't have two PMs of the same brand/type. Are they paired via ANT+ or BT?
  • Both power meters are connected via ANT+, and I initially paired them with the Edge 1050 using the guided pairing process on the device.
    When the issue occurs (which doesn’t happen every time), I don’t need to go through the entire pairing process again. I just go to the sensor menu and click “connect” next to the Pro MX-2 entry. That typically resolves it quickly.
