Enve road stem (NON-Aero stem) and 1050 - Fit?
I have seen several post about the enve aero stem and the K Edge mount and the 1050 not fitting properly. What about the regular Enve road STEM (i.e. Non aero stem) and the K edge enve mount? Anyone have experience with this set up and if the 1050 works on either the top or bottom bolts or both?
Thanks!
  • You mean the Enve k edge in front mount? I have one and the 1050 just barely fit if you don’t mind a little rub on the plastic cover of the charge port. I have access to a lathe and made 2 mm spacers. That was a clean and easy fix for me. On the other bike I had to order the k edge xl max mount. I can’t stand the clunky Garmin mount that came with the 1050.
