Endurance workouts of over 3 Hours
I have just purchased a new 1050 and it,s awesome
My question is....
For example If I,m doing an endurance workout of over 2 hours and I stop ( Let,s say for coffee ). I have to Pause the workout which is fine. The 1050 will go into sleep mode
But when I want to resume that workout again after 20 minutes of stopping for coffee It won't resume from where I left it and it will start from the beginning or it will even skip the entire workout and mark it as finished.
It would be nice if you could control your long endurance workouts and continue after a coffee break.
  • it seems that manual pause and auto pause work differently, because I've run into the same issue with manual pause with my 1040
    but with using auto pause (that is the preferred anyway, because running the activity while stopping at the red sign, for example, will ruin your metrics pretty much when using external analysers, such as intervals.icu) it continues with no problem even after a prolonged period
    my presumption is that because everyone uses auto pause, the manual pause issues are just ignored by garmin - maybe there is a deeper explanation, don't know
    just use auto pause, let's see if it helps!
