Hello
I have both the fenix 7 pro and edge and wamted to know how to best record an activity?
should I start activity on both?
Hello
louis16nw1 If you record an activity on both devices and save them both, you will then have duplicate activities. The recommendation would be to pick one device and use it only for each activity. Your 1050 would be the best fit for cycling activities of course, whereas your fenix would be the easy choice for activities like runs, yoga, strength training, etc.
Thanks for your reply. Would the fenix pick the edge activity then?
I apologize, but I am unsure of what you are asking. I would recommend you only record with one device for each activity. The choice of which one you use is up to you. Your relevant data will then be synced across all devices in your account, with compatible devices.
