I fixed mount on BLACK INC bar.
I used GoPro additional part. For example https://www.amazon.com/Adjust-Straight-Joints-HSU-Direction/dp/B01IQPD9DU
The consensus from the Factor folks is that it fits fine on the integrated barstem (straight front profile) but not on the integrated aero barstem (pointed front profile). Framesandgear has a Factor compatible mount specifically designed to fit the 1050 on the integrated aero barstem.
You can also add the Framesandgear one, it has a fixed base arm, but still with angle adjustability.
framesandgear.com/.../framesandgear-aero-mount-for-factor-black-inc-bars-for-garmin-edge-1050
