Firmware version 10.18 for the Edge 1050 Series is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
20% Phased Rollout as of 9/9/2024
Changes made from version 9.11 to 10.18:
- Added Garmin Share. Share your workouts, courses, and waypoints between compatible Garmin devices.
- Added ecosystem-wide Garmin Coach support. Train for an event, achieve a milestone, or improve your fitness with dynamic Garmin Coach training plans for runners and cyclists.
- Added GroupRide awards and climb competitions.
- Added road hazards support. Get alerts for road hazards reported by fellow cyclists and contribute your own edits.
- Added wind and stamina adjustments to Power Guide.
- Added surface type support including on the map, in-ride unpaved road alerts, and post-ride summary.
- Added Wi-Fi map download support.
- Added revamped Course Creator.
- Updated grade algorithm to be much more responsive.
- ClimbPro
- Fixed climb clusters failing to display climb details.
- Fixed an issue where the climb list page could highlight the incorrect current climb.
- Fixed climbs drawing on a course when ClimbPro is disabled.
- Retained the setting for the ClimbPro, Segment, and PowerGuide slider between page uses.
- Added support for India basemap.
- Added gear presets for SRAM 12 speed cassettes.
- Added a QR code to quickly pair a Strava account with Garmin Connect.
- Added search alias support to improve location searching.
- Added course search to the search bar.
- Fixed USB connection detection when coming out of suspend mode.
- Fixed crash that could occur when saving the ride.
- Fixed incident detection countdown timeout notification priority over any other notifications.
- Fixed infinite elevation calibration prompt following a manual calibration.
- Removed tone from elevation calibration prompt.
- Fixed mute toggle interactions on the notifications widget.
- Fixed pausing navigation.
- Improved speed of city search.
- Improved phonetic and hand-writing keyboard input.
- Fixed ride button failing to show after receiving and reviewing a Connected POI.
- Fixed friendly name for phone pairing.
- Fixed issue where hazards in China could appear offset on the map.
- Set minimum backlight level to retain screen visibility after backlight timeout expires.
- Persisted backlight level setting through battery saver enable and disable.
- Fixed battery remaining time estimate not updating when toggling Hide Map option in battery saver menu.
- Fixed display of battery level when it dropped below 5%.
- Fixed small roads on map being drawn too thick.
- Fixed behavior of menus from popping back to previous page to remaining on page after data entry.
- Fixed an issue where British coordinates could not fully be entered with the keyboard.
- Improved layout of post-ride highlights page.
- Fixed various crashes and freezes.
Changes made from version 9.09 to 9.11:
- Improved performance of hazards including fixing an issue where a hazard would not prompt.
- Fixed an issue where Power Guide target could display incorrectly after a climb.
Changes made in version 9.09:
- Updated GNSS firmware to 11.00
- GroupRide Improvements:
- Added descriptions and fixed values for GroupRide awards.
- Fixed issue where GroupRide shared code is lost if consent is required.
- Removed redundant time information in competition results.
- Fixed GroupRide course not downloading and failing to display after a ride.
- Fixed layout of awards list items.
- Fixed awards taking a long time to show up in history.
- Fixed errant climb competition winner when climb doesn't register as a competition.
- Fixed showing start distances for competitions.
- Fixed issue where a hazard would still be visible after a downvote on a ride.
- Added a QR code to quick link to pair a Strava account with Garmin Connect.
- Integrated CIQ glance theme support.
- Fixed crash that could occur when updating Power Guide.
- Fixed crash that could occur when navigating back to start.
- Fixed crash that could occur when using course creator.
- Fixed freeze that could occur during WiFi sync.
- Fixed key press behavior when battery saver display timeout is active.
- Fixed issue where a specific sequence could result in double swiping on timer loop pages.
- Fixed high power consumption on the map page after loading a course.
- Fixed battery saver estimate accuracy.
- Fixed showing the battery was charging when the temperature range was exceeded, and battery was not in a charging state.
- Fixed layout on the segment/climb dual approach prompt.
- Fixed multiple issues with graphical data fields.
- Added highlight to the selected data field.
- Fixed font size for large data fields.
- Added real-time settings menu for voice prompt settings.
- Fixed display of unpaved data in course summary.
- Fixed activity profile odometer not refreshing after a ride.
