Garmin Edge 1050 has multiple ANT+ sensor dropouts
I had multiple sensor dropouts on my Garmin 1050 on my last ride. It was an indoor training ride and my HR monitor (viiiiva) and trainer/power meter (Wahoo kickr 5) dropped out multiple times before reconnecting. My data on Garmin Connect shows the dropouts but my data on Rouvy never dropped out leading me to believe that is the Garmin unit itself that is the problem.
3 things to note:
- I didn't get the dropouts on my first 2 exercise sessions with the unit.
- The unit has since done a software update. I ma now running software version 9.11
- All my sensors were transferred from my old 1040. I deleted those sensors and reactivated then mid session to no avail.
This is very concerning on such an expensive unit.
Image showing no dropouts pre - update
Image showing dropouts post update
Image from Rouvy of HR data showing no dropouts post update
    1. Hi Phill. I have the same issues with my powermeter Rotor. The firtst rides all was ok. Next, powermeter was connected but no datas on 1050 and now my edge don’t find my powermeter or only few seconds. Powermeter is ok with Rotor App.
  • Hi Phill,
    I have the same issues with different power meters:Stages and SRAM spider crank.   Have you found a fix?
    gabe
  • If ANT dropouts occur on indoor trainings, it is worth to check the coexistence of wifi. Both are sending 2.4 GHz.
    Turn off the router for a test run.
    Change the wifi channel for further testing.
    On internet search you can find:
    Ensure that any local WiFi equipment is not transmitting on channels that overlap ANT transmission channels. WiFi (802.11b and 802.11g) can be safely configured on channels 1–6; channels 7–14 may start to interfere with ANT Wireless. Consult your access point user manual for information on how to change the WiFi transmission channel.
  • It’s happening outside for me,  on the bike
