With the Syncros / K-Edge integrated mount, the E1050 will fit any 2022 - 2024 Scott Addict Road & Gravel with “RR 2.0” integrated stem or the “Creston SL IC” integrated cockpit.
Approximately 1/4” clearance, no rubbing or interference when rotating the E1050 into the mount. Really nestles in perfectly with the integrated cockpit. Would probably fit the Scott Foil integrated stem w/ the Syncros computer mount due the Foil mount being almost identical to the RR 2.0 stem mount, but haven’t tested it.
