Does anyone has the garmin edge 1050 fitten on a Tarmac SL7?
Aha. You mean from underneath correct? Not sure I can do that as my barfly has integral go pro mount underneath that holds headlamp.
I also have a GoPro-Light support, I had to wear out the piece a little because of the screw but it is perfect, the other screw is hidden under the piece
Do you know what length M3 worked best?
thanks.
I have it cut to this size (1 cm.) and it works well.
Hi. It definitely does not fit with the given adaptor. Therefore, I try the MasterMount from Carbonworks as an alternative.
Hi. As mentioned bellow it does not fit to the given mount. Therefore, I am going to replace it with the MasterMount from CarbonWorks. I also use this one on my gravel bike with a longer version for the 1050, hopefully this will also work on the SL7.
Hi, is still possible to press the buttons next to the steeam?
Hi - Which mount are you using? Thanks
I use the original one from the bike, changing the hitch
