Garmin 1040 solar looses connectivity with venu HRM
I start cycling for any amount of time and the sync between Venu HRM broadcast and 1040 solar works ok. When the activity is paused or stopped, and then restarted, then the connectivity with that Venu HRM broadcast is lost. The sensor is there, I can remove it, connect to it or whatever, it does not connect again and the HRM data is lost. Even restarting both devices won't do anything, stopping the activity in 1040, stopping broadcast in Venu, won't do anything. I have to wait days in order to them work again, even removing the sensor from 1040 and trying to reconnect, wil do nothing (the HRM is never seen again after removal from sensors).
really tired of this. Happens the same with any HRM, instinct, HRM band, vivoactive2, etc.
A few monthis ago happened the same with the powermeter, it lost contact, sensor was there but doing nothing, if removed, never again was added back until days later.
Garmin needs to stop *** up things.
