Di2 12 speed left lever malfunction on version 27.14
Hello All,
My Dura - Ace left lever has a malfunction. When my Garmin 1040 is powered on the left lever doesn't work properly just after so many clicks. It seems to not connected to the rear derailleur which is the brain of the system. Surly it's a connectivity issue what causes the Garmin headunit. Because when it's powered off everything is working good.
Is someone facing the same problem? Even on lower model series like Ultegra or 105?
Thanks for the answers!
  • Hi, are all your Di2 components up to date with the latest firmware? I’m running my 1040 on the latest firmware and my di2 is bang up to date with no issues. Are you dura ace levers batteries original? Not sure if that’s connected to the issue or not but try reaching out to the guy over at
    https://bettershifting.com
    he is very knowledgeable and may be able to shed more light on this for you.
