Why is navigation on Edge so complicated and poor? ‍
Good morning everyone! I recently bought a Garmin Edge 1040 and it's a fantastic bike computer! However, I'm on vacation these days and I'm having a lot of difficulty with navigation. Why did they make it so complicated? Komoot it's 10 time better And even easier to use. Pensive There are many functions that cannot be activated if you are recording an activity (if I want to go to a place for example, I can not write the name of the city, why!?) If I have done 100km and I have to do another 100km, I don't really feel like stopping the activity and doing two, it doesn't seem like a logical thing to do, right? Trip planning from both my phone and Garmin is terrible, even trip planning from my computer and browser is bad and poor, why!? Navigation should be much smarter like Google Maps, not constantly telling me to make a U-turn. I would also need a distance counter and the time I have left to get to the specific place I set, like on Google Maps. Another very bad thing is that when I want to go back to the beginning of the ride where I started from I want to be able to choose between the routes to take, maybe I don't want to climb a mountain again.
    1. Tienes razón. Por ejemplo, no es lógico tener que finalizar una actividad y empezar otra si en medio del recorrido decide modificar la ruta con komoot para seguir otra porque no es capaz de sincronizar si hay una actividad en curso. Eso quizás sea lo más traumático e incomprensible. Es decir, tengo el iq de komoot pero no es completamente operativo porque no deja sincronizar rutas en marcha si hay una actividad en curso
  • Smartphones are much, much faster. Routing on Google maps is using even faster computers (with an internet connection). So, given the vast resources available to these alternatives, it’s not surprising they will do this better.
    Many people use pre-planned routes downloaded to the device. This works pretty well.
  • GPS devices with excellent navigational features existed before Noe - and well before Edge 1040.
    now, I see 2 reasons why the navigation is so restricted / badly implemented / buggy / non functional here
    1) bad management (requirement setting) and engineering
    2) intentionally bad
    as garmin is famous for razor edge thin targeting of devices (and heavily restrict any other user scenarios), I'd bet the 2nd option.
    honestly, at this point I'd simply remove all the navigation features from the Edge, because all it does now is to lead to unwanted "recalculations", lock ups and tons of bugs, even when all navi features under the sun I've disabled already.
    and yes, I disabled it because it was so bad to begin with.
    “Noe”?
    I’m guessing you are talking about devices for cars.
    These have unlimited power (they are plugged in). This lets them use faster computers.
    The address search function for these is much worse than with smartphones.
    The nav in smartphones is better too.
    Certainly, things shouldn’t be buggy.
    intentionally bad
    So, how would that be useful for Garmin?
  • It's not poor, it just works differently. Bike computers are designed to follow pre-defined routes while consuming the least possible amount of energy.
    A few weeks ago, I had to support a group of cyclists with a van. I tried a few navigation apps on my phone, including Komoot. None of them were able to properly follow the GPX route and display the map. At some point, the phone overheated and stopped updating its location. I brought the Garmin as a backup and it just worked.
    As for your questions:
    • Nobody plans routes on the Garmin, but it's possible. If you like Komoot, connect your Komoot and Garmin accounts. New routes in Komoot will automatically sync to your Edge.
    • You don't have to stop the activity for anything. Tap on the screen, the home button appears on the bottom. To go back to the activity from the home screen, tap the riding profile on the top of the screen. It probably says "Road".
    • You can navigate to a city by its name. On the home screen, choose Navigation - Search - Search button on the bottom right - Enter the name of the place. You can also share a place from Apple Maps with Connect and it will automatically show up on the Edge. But that's not a common way to do it, because when road cycling, the destination usually matters less than the specific route. You should plan your routes in your preferred tool, e.g. Komoot.
    • It sounds like you want your Garmin to display the estimated arrival time and distance left. There are data fields for that. If you don't know how to configure screens, read the manual or watch a video on Youtube.
    • U-turns: most people turn re-routing off, because they want to ride a specific route. User expectations for a sports device are different than for a car satnav.
    • Different route options: good idea, but probably too memory/compute intensive for a bike computer. Even calculating a single route can take a while. It's better to plan the route on the phone and sync it to the device.
  • Hi,
    the most power hungry parts of these devices are the display and the GPS unit and not the computational part, so that is not the bottleneck here. also, I had a device that is 20 years old now, and I can assure you, it has much slower cpu than anything garmin has now.
    and it navigated brilliantly.
    so that you are nagged to buy as much different device as much as possible.
    examples: both the garmin's gpsmap and fenix do have ETA fields, and auto stop functionality but they work very differently, so much, that the fenix is almost unusable for hiking (if you want use these features).
    sadly the gpsmap do have critical issues (it saves corrupted fit files), so it is also unusable for hiking ^_^
    also, garmin's small forerunners (265/570) do not have maps, while the larger ones (965/970) do have. but it is not the size, because a small fenix do have map.
    the problem here is that the large forerunners and even the small fenix is too heavy and thick to sleep with. well, it is doable, as I do with my large epix pro gen 2, but it is not ideal.
    so, at this point, you'd need 3 watches to cover as an everyday watch (570), a runner's watch (970) and an outdoor watch (fenix)
    would it be possible to do it in one, relatively small device? yes, but sadly garmin does not want that.
    the most disgusting part of the story are the hidden parts (such as data fields and other tricky parts, such to disable to wrist HR sensor during an activity while having a chest strap, not to corrupt the strap's data with garbage whr hallucinations) that you are not even aware of until you do want to use the device as intented.
    it is a dirty game and when you run into issues that does not make sense at the first sight (e.g. the toy like interface of the forerunners or the much dimmer AOD during activities with the FR265 vs Epix, or the dropped SW support for the last gen epix/fenix while having a model that has exactly the same HW as the older ones), you can be absolutely sure that it is not there because having insufficient calculation power for example.
  • the most power hungry parts of these devices are the display and the GPS unit and not the computational part, so that is not the bottleneck here. also, I had a device that is 20 years old now, and I can assure you, it has much slower cpu than anything garmin has now.
    The CPU speed matters too.
    I suspect a tiny number of people are buying more than 1 watch.
  • The problem is you.
    If you are not able to setup or manage your device it's not the devices fault.
    There is a German proverb for that:
    Wenn der Bauer nicht schwimmen kann , ist die Badehose schuld.
  • One of those things you mentioned is something that causes me grief too. The u-turn scenario. Once I ended up having to stop the route, and start it again (without routing to start) just to remove that message.
  • Yesterday, while on my gravel bike and riding in an area next to a bike-park, my 1040 wanted me to go down the downhill trails.... I understand that was the shortest way down but if I would have not known, it could have end up badly!
    Overall the navigation is sub-par. I also have a Fenix 7X and I think that works a bit better. Still they both want me to do some unreasonable routing sometimes.
    But I have to say that is difficult to know if it is completely SW or also maps related. Sometimes there might be a couple of meters of detail missing on a train and because of that the unit does not know it could route through it so it goes around... I also noticed that in my area some quite frequently used trails just disappeared from the maps (they were there some updates ago for sure!).
    The reality of fact is that if you can, pre-plan the route (and even more variants of it) so to be able to not rely on Garmin SW
