Map own position stuck using "Balanced Multi-GNSS"
So I recently set my GNSS settings to "Balanced Multi-GNSS" but ever since, I have this weird issue that when moving from my house and using a particular bridge crossing the highway, my postion gets stuck on Map. It switches back and forth by 180degrees (see video) but doesn't move. Even when being KM's away already, this keeps mappening and my position doesn't change. I have the video attached to this thread several KM's away from the position my Edge shows me to be at.
Weirdly enough, the Edge dus record my position correctly into the FIT file and this "being stuck" is not visible in Garmin Connect or any other app that's plots my traveled course.
My current workaround it to set my GNSS settings to any other option using the widget temporarily and wait for the position to become correct again (takes several seconds) and then set it back to balanced. I am running the latest 27.14 firmware so wondered whether anyone knows what is happening here and how to fix it?
Video on Imgur
