folders to organize courses
Soon I will be cycling a multi-day tour where I have the choice between different distances and elevation meters every day. So I have multiple routes per day. Is there a possibility to create folders to arrange the different routes per day on my edge. Then I don't have to search through the entire list of routes
  • I don't know if that possibility exists but courses are displayed in numerical-alphabetical order. You can play around with that a bit by numbering the routes by day. For example, 001-xxx, 002-xxx, etc. for day 1, 011-xxx, 012-xxx for day 2, and so on, so that they are grouped at the top of the list.
  • Is there a possibility to create folders to arrange
    No, the "Courses" folder only supports one level for displaying the courses in that folder, the course "calculation" functionality (pre-initiated on course loading) also puts parts of courses in the "Calcs" and "Point Cache" folders with similar/same naming. @DijkG's suggestion might be the best you can do, remembering the 100 course limit.
    PS Noting that the Display Name in the Courses screen is the internal name of the course and not always the same as the .FIT file name you see in a directory list.
