ClimbPro Incorrect Gradient & Lagging Issue
Huge ride today with lots of climbs and the climbs were all displayed incorrectly in ClimbPro. I tried with the route loaded and not loaded but both methods had huge discrepancies in the actual gradient I was going over and what was shown on the screen.  Also, when the route was not loaded, the climbs would say "Climb Complete" while climbing still remained.  A handful of times, the climb screen would popup with a totally new climb for the remaining portion of the climb (I am assuming) but the gradient was incorrect.
On the last, biggest, hardest climb, I did manage to get a screenshot.  In this blood red section of the climb, the gradient had to be over 15% but ClimbPro showed 0% for the gradient.  On many portions of the climbs throughout the day, the Edge showed negative gradients when the gradient was action between 1-3% according to other riders in the pelaton.
This started happening after the 27.xx update.
Thanks.
  • Haven't done much climbs yet so cannot tell if it was better before. with my 1040 but on Friday near Luik, the Redoute wasn't plotted correctly either. It showed a green segment near the end while I still had to push up for about 6-7%. On some other climbs, the Edge screwed me over as well as I was hoping for the green part to come up but it didn't happen.
  • The regular gradient display is also totally messed up now (again!). We get a firmware release that seems to fix the issue and then the next breaks it again, come on Garmin, you can do better than this!
  • This happened to me again yesterday on a long ride!  The elevation screen stopped counting ascents at about 6500ft of climbing and just showed the 65xx number. ClimbPro would still popup but the gradients were horribly incorrect!  I was going up a rather steep climb and ClimbPro showed -26% for the gradient.  Is my altimeter bad? Can I get a new 1040? This is pretty bad.
  • Hello Garmin, I am a user of Edge 1040 Solar, a 750 EUR device!! My gradient is *** up, it can show -11, -16 or even 20 or 23% on a 3% slope. It is completely useless.
    On top of that total elevation is also wrong and on a 2500 m ride accounted for only 1900m, can we solve this? Can I get this relaced or get a full refund on the device? This needs to be sorted out otherwise it is completely unaceptable as you can imagine
  • I have similar problems with ClimbPro. On my prepared courses (made using Garmin Connect online and transferred to my Edge 1040) the ClimbPro elevation profile seems off while riding.
    Might be a low resolution elevation map that has been smoothed poorly? Sometimes splitting a constant grade section into flatter and steeper sections?
    Makes for some unfortunate surprises when you were hoping for a lower grade section ahead.
