VO2 Max not updating 1040
Hi, I've recently noticed that my cycling VO2 Max hasn't been updating for nearly 5 weeks, despite having ridden many outdoors rides over that period.
Hrm is new and always wear it when cycling and running.
My 1040 is running 26.18 software which I believe is up to date.. Tried to update but says none available.
So, I've seen many posts on this same subject but not found a solution yet.
Anyone on here make a suggestion?
Thanks
  • Do you see the unchanging VO2 Max on the Edge itself or in Garmin Connect? For GC that would be rather normal because VO2 max is rounded there whereas on the Edge you can see the a graph with a much finer resolution.
  • Its not changing on Garmin Connect app, and the Edge doesn't differentiate between VO2Max and Cycling VO2Max (not sure why it tracks this differently either).  EG. my VO2 Max is 47 but my Cycling VO2 Max is 48.  The GC app tile is blank and specifically says "Track outdoor rides to reveal your current VO2 max", but I am tracking outdoor miles.
    I've never had any issues in the past, this has only recently started showing this blank tile.
  • You laid emphasis on your new HR monitor in your original post. Do you have a power meter too because that is needed for cycling VO2 max?
