My auto pause is set at 3mph and timer start mode set manual. When i start a ride the auto pause does not work at all. Tried 5 times but timer goes over 1min and still not stopping.
deathzone I am slightly confused after reading your post about which part of the auto pause feature is not working as you would expect.
Are you saying that after you manually start a ride and then slow down to a speed under 3mph that the timer continues to run? With your permission we can look at this ride if it has been uploaded to Garmin Connect as long as you provide the date this was recorded.
Think i've found out what's wrong. When I start a ride, in the speed box it shows - - the auto pause will not work. When I start a ride and there's 0.0 in the speed box the auto pause works.
Think I've found out what's wrong. When I start some rides there is - - in the speed box. Auto pause will not work. If a start a ride and there's 0.0 in the speed box auto pause will work. Think it only happens at the start of a ride. once the speed starts showing in the speed box and you stop, the the speed box always shows 0.0
I assume, you don‘t use a speedsensor. And that‘s what I told you in my posting above: Autopause works only with a GPS lock (when GPS is enabled).
