25.25 - random lockups. Need confirmation
Since I installed version 25.25 Edge has been showing random hangs during activity:
- response to changing the screen via the edge remote control - sometimes the screen does not change to the next screen, to then jump after a few seconds by the total number of presses of the remote control button
- speedometer starts showing speed after 20 meters of driving, instead of after 3-4 meters ( I use autopause)
- Odometer+ widget updates its distance fields with a delay.
All this happens at random times, nevertheless, since I installed version 25.25 the device behaves as if it can't process the data, which results in such lags in operation.
Do any of you have similar impressions?
P.S. this is not the result of a configuration change, installation of some new widget, etc. The only thing that has changed in the last two-three months is just the firmware version. On the previous firmware none of the described cases occurred. Today while driving to work, for about 2-3 I disappeared all the values from 10 data fields on the screen. This is not normal.25
  • Hello, I have a 1040 and I can confirm I have lot of lockups since the last update:
     - screen not responding to touch screen or buttons for 5 seconds or more  (I often create 5 laps in a row because of  the edge not responding to buttons)
     - lags from some data fields
  • My 1040 froze and I had to do a hard reset.  Didn't record the last 15 minutes of my indoor ride.  Software 25.25
  • I have been getting this issue for last month since update 25.24, the device is almost unusable as every action you perform takes several seconds or does nothing, which can be dangerous when riding offroad or even on roads at over 30mph
    honestly last updates make me really think to leave all garmin products and get wahoo... unbelievable after 10+ years
  • I just updated to 25.25 on my Edge 1040 (non-solar) today before my ride and also experienced random freezes. Noticed it when gear combo and 3s power wasn't changing when shifting with di2.
    Please fix this Garmin!
  • Yes, lately I am also experiencing lockups of around 5 to 10 seconds where the 1040 non-solar doesn’t react to DI2 input to change pages. Then suddenly catches up and switches the requested number of pages. My 1040 is on firmware 26.14.
  • Can confirm the 1040 hanging up, though mine occurs at exact 5 minutes intervals rather than random.
