The backlight disrupts the temperature reading, but not in the way you’d expect. It goes lower!
Is this normal behavior for the 1040? The temperature reads correctly until the backlight turns on. After the backlight turns on, the temperature drops by about five degrees celsius (about 40°F(?)). When the backlight turns off, the temperature gradually returns to normal. The higher the backlight brightness setting, the greater the temperature difference.
I have also owned devices like the 820 and 530, and this has never happened with them.
Video: drive.google.com/.../1vHRgpx1fFRTrcTGdyleB7sTKB1ER2ypr
