Missing History option from device
Hi,
Ever since the previous update (21.18) I don't have History option/menu on my device. First I thought it was moved somewhere, but I can't find it anywhere. I really need it because I ride a Rohloff equipped bike, and I switch profiles, so I need to calculate the totals to know when's a time for oil change. I didn't switch phones nor accounts, just done the update via WiFi. Anyone else has this issue, or knows how to get this option back? Thanks!
  • Do you mean the widgets? Those can be changed as described here. If that doesn't help, the most common advice would be a reset. Make sure to do a back-up beforehand.
    Also, you can use Garmin Connect to track history and totals.This is even more dependable, because it has no limit on number of activities, and doesn't get wiped if the device is reset. It also makes tracking multiple bikes a possibility.
  • I think though the OP is referring to the "History" Glance on the home screen (along with usually Navigation, Training and others. If the "History" Glance is missing then scroll to the bottom of the home screen where you will find a Pencil symbol, press this and you get a list of the Glances you currently have on the home screen, you can delete or move them around. To ADD another press the PLUS symbol and select other Glances from a long list, among them will be the History Glance
