Connection issues 4iii pro dual sided and Garmin 1040
Hi, I have an issue with my dual sided 4iii pro, only one crank will connect to the Garmin 1040, if I connect one, the other side drops off. Is this a known issue?
  • because you wanna pair it via bluetooth (and in this case the 4iiii two sensors, /it is not bridged/ but the Garmin can handle only one power sensor ) pair it via ant+ only (where the 4iiii only one sensor and the 2 sides are in master and slave connection)
