Edge 1040 Assioma Power meter sensor drop
I have a brand new Edge 1040 non solar version.
I have the Assioma Uno power meter for a couple of years and had it connected to a Wahoo gps unit without any problems.
Recently I noted some sensor drops during the ride. It disconnects for a couple of seconds and the reconnect again. I have even joined the Beta program and have updated with the latest version, but this is still happening.
This is getting annoying.
Anyone else is having the same issue?
UPDATE: Only having issues when connected over ANT+
  • I seem to have fixed the problem.. I've disconnected the pedals from the Garmin and then reconnected them. Just make sure you change the crank arm length and calibrate them again. Seemed fine after that.
