Elevation Problems after upgrading 21.18
This morning i updated my Edge 1040 Solar to 21.18 FW; in the course the elevation was completely wrong ad arbitrary,  as you can see in the attached course.
https://connect.garmin.com/modern/activity/16039227659
  • Working fine for me after the update
  • Hi,
    You can try these 2 things (guessing the English settings as mine is in Dutch):
    1) Make sure you have the Worldwide DEM map enabled (demographics, used to automatically calibrate based on your location) :
    Profile - Navigation - Map - Map Information - Enable: Worldwide DEM Basemap (NR, v8)
    I also have a Garmin DEM Map EU 2023.10 listed, but I have this disabled
    2) Go outside and then: System - Altitude - Calibrate - Use DEM
    Should be accurate now :-)
