No longer avle to see the Di2 gearing info after Update 21.17
Hello all.
after updating to 21.17 I can no longer see what gear I’m in, gear ratio and all those data fields related to my gearing. The bike is a Giant Revolt E. I’m connected ok to the bike and I have the EW EN100 also mounted to use for other bits. I can see the bike battery info (all things related to the bikes battery info, such as range, battery level, assist mode etc.)
But I can for the life of me no get the gearing info. I have been to Settings->sensors-> sensor details. I can change the setup on the shifters but the option to toggle the gears is not there ( not even automatic so it uses the steps setting), and definitely not gear presets or custom option!
when I then I go to my non e-bike with force AXS eTap, there is no issue. Everything works fine.
and everything worked fine prior to the update to 21.17 ( can’t remember wich version I was in prior to the update, but hadn’t updated for maybe a year).
Usual Garmin bug with updates ( customers used as a test bed) or a user error on my side?
