1040 USB-C waterproof cap
These days it rains often, I went out, it rained a lot, when I came back I wanted to charge the 1040 again, and when I opened the cap, the usb-c port was filled with water, it This is my second 1040 and they both have the same problem.
If you are not careful, there may be a short circuit when connecting the charging cable.
Garmin!
How come you go backwards with every new gps unit you design, the days of the edge 705 are long gone, but with its rubber cap there wasn't a drop of water on the charging port, and as curious as it may seem, you used the same type of cap for the Varia, why not do the same thing with the 1040?
Please Garmin, make your GPS units reliable over time.
You can review the design and reliability of this cap, we will apologize if you could provide a correction of this cap to your customers who bought this 1040 for a fortune, make this modification, because there may be a lot of 1040s which will smell burnt because of a hidden screw coming from this little cap.
