The beta firmware has connection problems with 11-speed sram red etap, it connects and disconnects continuously and indicates the speeds incorrectly.
In edge 840 same problem.
Do you mean gear position/size rather than speed?
Try deleting the SRAM airing and add it back to the Edge.
Have you recently updated the SRAM firmware? If so you may need to go through the shifter pairing process again with the reset of the SRAM system.
Yes, it incorrectly marks the size of the gears. I have deleted the speed change and paired again and the error continues, the problem is with the firmware because it has the same error on my edge 840 and 1040. As a curiosity, once the activity has started and approximately 5 to 10 minutes have passed, Disconnections are less frequent but they exist.
So to be clear the issue with the speed sensor and not the SRAM eTap system?
El problema está en el sistema de cambios Sram Red Etap, ajusta mal las marchas y se desconecta continuamente. Borrar sram red red etap y volver a vincularlo no funciona.
Not sure if it is the beta, I’’ve had this problem since last september, with beta and the last release version.
