I can't find the power guide target (or any power guide field for that matter) in any of the available data fields to add to another data screen.
Am I missing anything ?
You can create and use a power strategy to plan your effort on a course. Your Edge®device uses your FTP, the course elevation, and the projected time it will take you to complete the course to create a customized power guide.
One of the most important steps in planning a successful power guide strategy is choosing your effort level. Putting a harder effort into the course will increase the power recommendations, while choosing an easier effort will reduce them(Creating a Power Guide). The primary goal of a power guide is to help you complete the course based on what is known about your ability, not to achieve a specific target time. You can adjust the effort level during your ride.
Thanks, I did read the manual, but unless it's right in front of me and I don't see it, I don't see any mention that power-guide-related data fields are not available outside of that single power guide screen.
The problem with the power guide screen is that the only layout available is 2 small data fields, not even a double-wide to use connectiq apps like MapDashboardMS, so it make it very impractical.
Adding one power guide target in another screen would be sufficient for my use case, and I would settle for a single, double-wide field (with a good connectiq data field) on that screen if that was the only option.
"I don't see any mention that power-guide-related data fields are not available outside of that single power guide screen."
I don't se it from the list of available datafields, so I suppose it's a "take it or leave it" situation....
www8.garmin.com/.../GUID-53FC7978-187F-4E53-AA33-04853F86B05F.html
Yeah, it looks like you're 100% correct.
