How to disable the "pause navigation / reroute" screen when going off course?
When I go off course (or just the edge thinks I went off course), a screen always pops up with "pause navigation / reroute".
How can I disable it? When I ride I want to ride and not to interact with the edge in every minute (btw: selecting "pause navigation" does nothing, the popup will stay there). This pop-up blocks a very significant part of the map, even at the worst time, when I want to navigate back to the course.
So my map is blocked by this popup and I cannot do anything with it while the edge will find the course again, and sometimes that takes a long time despite being on the course.
  • Course Recalculation: Auto Pause* and Route Recalculation: OFF works for me, no pop-up / prompt, but you might have different needs (*pause the navigation not the activity)
     Menu>Activity Profiles>(Select Profile)>Navigation>Routing>Course Recalculation & Route Recalculation
    Use the Map course Line to get back to the course, the navigation should pick-up from there when the course is “found” again
  • Thank you very much, it works perfectly! Sunglasses
