It should automatically go to sleep after 5 mins . It does not. Anyone has this issue? it only goes to sleep only if I press the power button .
Previous discussions suggest it sometimes takes longer than “5 minutes”, I guess it thinks there is some “activity” that keeps it up late, perhaps solar charging has causes some delay? I get close to 100 hours from my non solar with minimal battery usage settings so don’t think I would ever need auto sleep.
IF my phone with GC running is conected to garmin it will never go to sleep.
My 1040 is behaving normally, including when connected to a phone via Bluetooth. I don't normally leave the device on for long enough for it to reach that point, but did so today while it was synching after a ride; when I returned to it some minutes later, the device had entered sleep mode.
I carried out a factory reset shortly after 20.19 was installed, because initially the device seemed to be sluggish; that may or may not be relevant, but in any case, the issue others are experiencing is not general, even if it's common.
