Edge 1040 Series SW 20.19
Firmware version 20.19 for the Edge 1040 Series is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
100% as of 3/14/2024
Changes made from version 19.22 to 20.19:
  • Added NavIC support.
  • Added keyboard suggestions to the location search feature.
  • Fixed crash in extended display mode when executing a workout.
  • Fixed writing free climb category so that it displays in Garmin Connect.
  • Fixed crash for long distance rides.
  • Fixed POI search for conflicts in the map data.
  • Fixed auto pause resetting smart trainer resistance during workouts.
  • Fixed light network battery status icons for components with an external power source.
  • Hid disconnected radar icon when in an indoor activity profile.
  • Fixed issue with pairing multiple BLE sensors.
  • Fixed crash when connecting to RCT715.
  • Fixed live segments updating during activities.
  • Fixed the resume navigation feature after diverging from a course.
  • Fixed truncation of creation date for courses in the dynamic glance area.
  • Fixed refresh of mobile notifications page.
  • Fixed ClimbPro behavior on bridges and through tunnels.
  • Fixed ClimbPro climb detection on branches with loops.
  • Clarified whether the source of an automatically detected maximum heart rate was from directly measured values or estimated from the user's activity history.
  • Fixed elevation plot overlap with map while zooming.
  • Fixed displaying emojis in startup.txt file.
  • Fixed other minor issues and improved device stability.
Changes made from version 19.19 to 19.22:
  • Fixed auto backlight issue causing battery drain.
  • Fixed BaseCamp compatibility.
  • Various Bug Fixes
Changes made from version 18.25 to 19.19:
  • GroupRide
    • Improved GroupRide scheduled ride time picker.
    • Fixed GroupRide keyboard showing non-English keys.
  • ClimbPro
    • Added shortcut to ClimbPro screen by tapping the "Climb!" prompt.
    • Added estimated time to end of climb for Time To Destination data field during a course ClimbPro climb.
    • Fixed elevation page and ClimbPro for indoor trainer course use.
    • Fixed invalid climb split cadence values.
  • Enabled manual setting of Resting Heart Rate to enable Fitness Age calculations on Garmin Connect.
  • Added smart notification images for apps that support them.
  • Enabled workout auto pause when activity profile timer auto pause is enabled.
  • Added button support to elevation data screen for axis scaling.
  • Updated VO2 Max page to show four weeks of history at a higher resolution.
  • Added prompt to make it more difficult to accidentally discard ride.
  • Increased touch area for music controls data page.
  • Fixed auto scroll timer loop and menu indicator interaction.
  • Fixed CIQ alerts crash.
  • Fixed Korean keyboard translation.
  • Updated Twitter references and icons to X.
  • Fixed Di2 shifter ordering in battery data field.
  • Fixed syncing auto detected FTP and lactate threshold heart rate to Garmin Connect.
  • Fixed front gear data field for Classified Powershift gear hub.
