Since the last one or two updates (wasn't riding in the winter much often) now i have the follwoing bluetooth issue:
in the beginning i thought on my sram quarg loses the connection to the garmin device if i do a break during a ride. I wasn't able to reconnect it. i took the batterie of the querg powermeter on and off. after that i was able to reconnect. Thought this is an batterie issue.
on my next ride again the powermeter get's lost but i put a new batterie inside my powermeter. I had to switch off and on my garmin during a ride, which isn't a great feeling because in the past i lost a ride (now it seems to work better).
But today !!! all bluetooth connection !!!! are lost (hearthrate, power, sram force) after a break. And !!! my iphone wasn't connected anymore too .
Because i started already the ride with a group i could power off the device and had to do it on the next break. I must power off and on the garmin and then everything works fine.
Garmin what should i do? On each ride ride with a longer break the device is not working (no to do a break isn't an option).
Any others here in the forum had similiar experiences and/or solutions ?
i have fthe firmware 20.18B installed
Best regards
Frank
