Am I the only one having issues with the data fields on the 1040 Climb Pro page?
In settings it shows zero data fields and the fields on the Climb Pro is empty and not changeable.
Not on the screen nor in the Connect app.
Any fix for that?
Any fix for that?
I can confirm a strange behaviour:
On my 1040 I have 2 fields presettet (instead of 0 - left picture). The 2 datafields are filled with data and changable (right picture).
BUT:
I canot change the number of datafields (left picture) to 1 or 0. Always stay 2.
Seems to be a bug (I‘m on Beta 20.15)
The number of data fields should be unchangeable and set to 2.
Would you be willing to share the activity profile you are having this issue with?
Sure. You gave an idea that is only in a certain profile there is an error - that is correct.
I think I at some point tried to use an IQ field that needs the complete space of two fields.CyclingRoad1_Lande.zip
Try placing this in the Garmin\NewFiles folder
I changed the number of data fields for the page from 0 to 2.
Thank you. How did you edit the FIT file, ie. what tool did you use?
I haven't been able to find any software for that.
The solution for most people would be to delete and re-create the profile. Editing it is not really an option.
