Varia connection mid activity
Normally I use the following sequence in the morning when riding to work:
- switch on Edge (1040)
- switch on Varia headlight (UT800) (-> gets detected by Edge)
- switch on Varia radar (RTL515) (-> gets detected by Edge)
- start activity on Edge -> this turns on the lights as everything is in auto mode
In the evening I don't need the lights from the start of my ride, so  I want to switch them on as it gets dark.
However if I turn on the headlight and radar AFTER the activity is started, the radar and headlight isn't being detected by the Edge.
I can manually connect to the radar under the sensors menu, but there is no way to connect the light.
Any ideas?
