Hide map on the climb pro screen and add 2 more data field on the screen
   It would be nice add 2 more data fields to the clim pro screen and remove the map in this screen (or have the possibility to choose or not). I would like choose the middle of the screen as a data field and make myself my own climb pro screen with the values i want. I think make it the most customizable is the best for averyone. What do you think about?
  • I have my 1040 since 3 days and this is quite annoying. I don‘t get it why it isn‘t configurable.
    Also why I can‘t choose individially where I want a wide date field or not. If I want 8 or 9 data fields, I don‘t want the wide ones at the top. Quite annoying in year 2024. But this is a different story.
  • I have the same problem.
    I have changed the fields on the climb screen (to be HR and Power), but when ClimbPro comes up, it still reverts to distance and ascent remaining.
    why can they not be adjusted?
  • Please let users turn off the map on ClimbPro. I want to focus on the climb, not a map.  I know where I'm going. The map reduces the space on the device's screen which should be dedicated to climb data.
  • I think I have solved this problem.
    Its a bit tricky as you have to wait for ClimbPro to be active, but you can then press and hold a field and get the dark outline, then tap it again to change it.  Then select the 2 fields you prefer (for me HR and 3s Power) and click to confirm and that is updated.  I had to do it for each profile (road and gravel).
    it’s fairly hard doing it while on a climb!  I can’t help thinking there must be an easier way!
