Hi I have recently purchased the Edge 1040 solar and have noticed the battery life has reduced significantly it was ok when I first brought it and now dies so quickly. Any advice as to fix this would be highly appreciated
Just in case there's a language issue here - "backlight" refers to the screen display, NOT the Varia - you shouldn't find that the brightness setting of the Varia has any effect on the Edge 1040 battery. It will have an effect on the Varia's battery, obviously.
Also, make sure that you have updated to v.19.22 on the Edge - the previous version (19.19) had a highly detrimental effect on the battery duration.
