How can I fix this problem?
Others have been there and report a resolution, searching will uncover more, if reset does not work for you then contact Garmin Support
Hello @L.Rouge, I discovered that my Garmin 1040 Solar starts to rebook as soon as I add one of my sensors. This problem started after I have updated my Gamin Edge. The sensor that I can't add is the Garmin Varia RCT 715. Every time that I add my gamin starting rebooting without stop. I have to turn off the sensor or go away out of range in order to delete the sensor from the Garming Edge. I have already done the factory reset on my Garmin Edge and I have pressed the two buttons on the Garming Varia RCT 715 to reset this device also. I don't know what I should do to have my sensor (RCT 715) working again with my Edge 1040. Do you have any suggestion?
